- 16 Nov 2003
- Thessaloniki
i can join tonight as well, have a 738.
I'd suggest looking at Squawkbox - it is probably much easier to get set up than FSInn.
I am hoping to make tonight, but Virgin are having serious problems in my area (DA16 postcode).
Tried to join the ocuk server and it says there's no slots left (2/2)![]()
Great night last night. Just need to get up to speed with my ATC lingo![]()
stevie will give you a hand with the fsx 737, not sure what was going on last night. I do highly recommend the the ifly or the pmdg. A lot of reading at first and frustration but all worth it in the end.
http://faq.apollo3.com/ljames/fsinn/vatsim/faq/#PlaneFollowingPilot
A plane follows me
Disable Automatic P2P establishing. This allows you to easily fly P2P with pilots of your choice and not have the problems with clients with faulty configurations.
Inn Control Panel -> Set -> Network -> Peer To Peer -> (Check) Disable Automatic Peer to Peer establishing.
After this setting you can selectively P2P connect to each plane and identify the culprit to eleminate.
Installing the Loopback adapter alsoresolves the issue and retains the benefit of P2P. Please test this and report the results to the forum (instructions for installing loopback adapter in question #4).
P2P which is enabled by default allows faster updates (realtime) and a more fluid motion. This is especially benificial when flying formation.
Sparse Grid Super Sampling. It is a setting in Inspector.
This is the guide you need to be reading:
http://forum.avsim.net/tutorials/article/59-software-hardware-guide-for-fsx/
http://avherald.com/h?article=4513b280&opt=0
hard landing anyone?
@V, have you installed any 3rd party apps like rex?
