- 16 Jun 2012
did you use ATI flash for windows? wont work through windows, says its a different subset or something....maybe DOS?
using those mod drivers for the 7850 and any overclock eventually crashes with a purple screen
any ideas?
Do you have the bogstandard HIS card, or the IceQ 7850 ?I reapplied TIM to both cards. This is what it looked like when I removed the shroud. I can't say I've noticed any temp difference after applying Phobya compound, but it was safer to re-apply some new stuff.
SNIP
edit - whilst idle temps are the same, during load the card is around 10 degrees cooler from what I have seen so far. So I am very pleased. I guess that the liquid pro stuff would have been even better, but I don't have any of that TIM lying around.
I'm going to reapply the thermal paste on my reference HIS 7850.
One last thing, what did you use to clean the stock thermal paste off ?
Uninstall em, Same thing here. I also have HIS card and I'm begining to wonder if any driver is completely stable.. overclocked or not. Gone back to amd_radeon_hd_7800_8.95.5_win7-64 for now to see just how they get on with no overclock or range enhancements or catalyst control panel at all.
Did you have any luck with the bios flash?
1.225v is the BIOS limitation for the Sapphire cards. Sapphire also use a custom PCB so you probably cannot flash the BIOS to circumnavigate this limitation.Hello!
I have a sapphire 7850 2GB, and I can't seem to overclock it past 1100 mhz without being unstable.
I am currently using sapphire Trixx, with the fan set to 50% fixed.
TRIXX only lets me up the voltage to 1.225, and I would like to go to 1.25 but none of the software I have found will let me go above 1.225, or the voltage control is just disabled. I have tried GPU tweak with extended overclocking, it still does not let me increase the voltage above 1.225 at all, same for MSI afterburner (even with unoffficial overclocking enabled) it will not let me even modify the voltage.
I wonder how many 7850's this thread has helped sell worldwide?
AMD should send me a nice present as a thank you. I'd like a GTX 690 please.
Not unless you are prepared to physically mod your cards voltage by soldering. 1100-1200 is the normal overclocking range for these cards, and to be honest there is very little real performance difference within that range.Okay, thanks!
Is there any way to get around 1200 mhz stable for this card, I have tried it at 1150/1340 and it is mostly stable, but the driver crashes every so often and sometimes has a pattern-crash that I have to reboot to get out of.
Speaking of drivers, are there any better drivers to use that don't crash as often when I try and overclock?
Yeah, I understand that no two cards will be the same, just I'm still a bit unsure weather to go for the MSI or ASUS. Noise isn't much of a problem for me really. Heck, my PC runs at 100% all the time, even on idle at around 25c. The surrounding I'm in is quite loud, so fan speeds etc isn't much of a problem.
Which was the best at keeping low temps at stock if you remember?
Also, I understand the GTX 670 is quite abit more powerful, but I'm only a mediocre gamer, not hardcore full MSAA etc;.
Also, I appreciate your very fast reply.
.There's a couple of HIS 7850's brand new on the bay, for around £160. What do you think? Should I go for it? What were the temp's like?
Little edit:
Just wanted to add I'm not too keen on products that aren't really big name brands (MSI, ASUS, GB), so I'm abit weary as to getting the "HIS" 7850.
Also, the fact its on the bay, doesn't make it very convincing.
I was considering a ASUS CUII at first, because of its large cooler, I would have though it would have kept the card nice and cool.
Indeed. Seems quite dodgy to me, I won't touch it. I like my stuff sealed anywayJust looked at that and I wouldn't touch the bay one with a bargepole tbh, they offer a 5 day return period and thats it, whats going to happen if it breaks after that, will HIS cover it??? Plus i presume you would have to pay to return it to germany etc
Also love the way in his advert it says the warehouse is outside of london, looks like the pics are taken in his kitchen![]()
