Caporegime
- 7 Apr 2008
- Lorville - Hurston
It tells you in most ROM instructions.
After connecting the phone via USB and putting it in fastboot mode, you just open CMD (cd to the relevant folder) and type: fastboot flash boot boot.img
(boot.img being the file that the ROM tells you to flash)
Alternatively, like on ArHD7, there are pre-made .bat files just for this.
Use this: http://forum.xda-developers.com/showthread.php?t=1592355
is this expected when i try to flash a karnel?
C:\Android_Fastboot_KIT_V2.0\Android>fastboot flash boot boot.img
sending 'boot' (4352 KB)...
OKAY [ 0.576s]
writing 'boot'...
(bootloader) Format partition LNX done
OKAY [ 0.487s]
finished. total time: 1.064s
edit:
hi all. i tried to flash this rom just now and it diddnt work. after installing the new karnel like this:
OKAY [ 0.576s]
writing 'boot'...
OKAY [ 0.487s]
and then doing a wipe on data and cache, i them attempted to install the rom.
it installed fine and then i rebooted the phone and it gets stuck in a infinite loop on loading the splash screen and then rebooting the phone again.
any suggestions?
