Yep, that all sounds right.
Leave the CWM that you have, it'll probably be the same one in the .bat folder.
What do you mean?![]()
robbo u jabroni!! THIS ROM IS AWSOME on my battery life so far!!
down to 75% and its been off charge for nearly 8 freaking hours! The battery hardy drains when not in use and i have everything synched via two gmail accounds, facebook and twitter. so good so far
Hows your screen time looking?
Anyone running any nice themes? Share
I'm also thinking of trying Franco R11 kernel, anyone had any experiences with it?
2hours or so, i have not tested it properly. will do tomorrow.
how do u take screenshots by the way? the normal way of pressing power button and volume doesnt work on the maximus mod?
ahh seen ok cool. thought i may have got it wrong. cheers. ALSO, diddnt u say that this mod gets rid of the onscreen menu button? mine is still visible?
Was that auto brightness?
That's good! When you mix up your use a bit (so use of apps and web browsing), it does take more of a toll on the battery than watching a video for instance.
What was your usage? How long was wifi and the mobile data connection on for?
