But I have never, nor will I ever attempt it my self.
As bad as it sounds it seems like too much trouble!
You have bought a Chinese bike and they tend to rust at a prodigious rate. If you want to keep at least some of it's value then you need to look after it.
My 2p worth here.
It's a Chinese low capacity bike. In 3 years when it gets to MoT time it will be worth nothing. It will still be worth nothing shiny and gleaming.
I don't see the point.
If it was something with some modicum of retained value after 3 years then yeah, do it.
I see a Sinnis Stealth (same engine by the looks of things) on a 2009 plate for £650. That's the kind of retained value you're looking at.
I've bought a Chinese bike before for my mrs but it was stupidly cheap at £500 for a 1 year old HN125. I sold it for £450 2 years later. There's no way I would drop the best part of two large on one.
Oh, and it's not a Suzuki engine. It's a "Suzuki designed" engine which means it's based on a pattern for probably the GN125 motor. The HN125 we owned had a "Honda designed" engine which was based on the CG125 lump. In no way was it even remotely as good as a CG125 engine. It was shockingly bad actually.
if you can ride a cheap bike that vibrates, you can ride one that don't.
I didn't say don't maintain it did I. That would be stupid.
I said, no need to spend out on having it sprayed with something to keep it clean.
With regards to ACF-50 are the spray cans decent enough? How much do you put on and are there any areas you don't spray it on the bike?
The best way, is to put the can in a mug of recently boiled water for 5 mins, this makes the liquid very easuy to apply. Spray this onto a rag, and wipe any naked metal basically. There is nothing that it 'can't' got on. They use it on airplanes. Literally spray the entire engine bay of the stuff! Honestly, you will thank me later![]()
Indeed.
There is no need to ride a cheap bike that vibrates when you can have a cheap bike that doesn't vibrate for the same money (allbeit slightly older).
Seriously though, if you haven't actually ordered this thing yet, stop and take a look at a used Honda CBF125 or CBR125. They are much better machines and you will enjoy riding and learning a whole lot more.
Ok thanks for that
Bhogal. Some of the guys here do have a good point on getting a Jap bike but then again if the Sinnis holds up well for the time you use it and you are not fussed about re-sale value when you upgrade to a big bike then it will be like Christmas, birthday, Easter, New Year and your dirtiest fetish all rolled into one climax once you plonk your rear on a Jap/German/British bike!![]()
You may laugh mate but i've seen it done, DON'T put it on the brake discs!![]()
Hahahaha, that goes without saying!
Lol i know you wouldn't but have seen some younger riders give it a go![]()
I used to ride with this one guys, real nice chap. New to biking. Brand new GSXR, from a 125 thing. Went to his to spend half a day giving him the lowdown on what to clean, how to clean, whats to maintain ect ect.
Went in to make a tea, came back with him cleaning the disks with WD40!!! I just laughed and said "I will ride this for a couple of miles before you hop on it otherwise your leathers will need dry cleaning" lol.
