What car cradles are everyone using? Need one badly.
I decided to treat myself to the Brodit active one with cig charger, works a treat although I find the USB doesn't always line up first time.
Two reasons really:
1. HTC are going to ruin it with HTC Sense, and that makes it significantly less exciting
2. It will take months for it to arrive at the very least
It's not really going to be up to your mobile provider unless you've got a carrier modified ROM, in which case it will take even longer.
This is the most interesting thing: http://forum.xda-developers.com/showthread.php?t=1737736
However it's going to be a while before it's worth using.
Think I might have the wifi squeeze issue after a bit of testing![]()
How easy are these phones to pop open.
WiFi literally buttraeps my battery at the mo![]()
With all the bugs of sense and the mobiles themselves etc. for you most definitely not!!!!![]()
Yes, but considering the massive amount of manufacturing defects, you'll probably end up being sectioned.
Ah, ok thanks Robbo. First Android device so not experienced it before, hopefully JellyBean will fix it!
what I'm using to fix the low res problem:
https://play.google.com/store/apps/details?id=com.jgarrison.hdcontacts&hl=en
