u already do to a certain extent.
Im not hiding from anyone lol
Not quite sure your 'location' on your profile and out right drawing a map to your house is the same lol. Oh well, your choice
lolMy patience is failing fast with BT, been having issues with FTTC lately.
Been getting 0.01Mbps upload on several occasions during the last two weeks, raise a ticket with BT, & got an email saying 'The connection is running within acceptable limits as set by our suppliers'.
Lost for words when I read that this morning, is it worth while taking the complaint further, but who to complain to.
Do u guys think this is slow for the distance from cab 57 to my house? Can i change cab? Is there any way i can find out if my overhead wires are copper or not? I guess most info ill have to provide when line and bt infinity is installed?.
I knew of several people who hopped from the Combe down exchange to Kingsmead just to get fttc, one house had two lines, one Kingsmead & other Combe down, due to which pole they were using.![]()
That's very interesting, will look into that! Unfortunately for wiring (but good for aesthetics) our road all has buried cables rather than poles so it might be a bit more work...
stats below if it helps
Helps what?!? Anyone else confused?
did u not think to read more than 1 post?
Indeed I did.
However ADSL stats don't have anything to do with FTTC/VDSL2 and therefore your post is completely superfluous.
Did you not think about that?
Is it possible to get rid of the Openreach modem and just have a router? In other words are there any routers at all with the modem built in?
