Well I think the wrapper version is the simplest. You just put a file (d3d9.dll) in the Skyrim folder, no need to run injector before you play the game.
In the enbseries.ini you have [EFFECT] section where you can turn off SSAO and DOF.
EnableAmbientOcclusion=false
EnableDepthOfField=false
FXAA is built into Skyrim and can be turned on/off by starting Skyrim Launcher. SMAA is a mod http://skyrim.nexusmods.com/mods/16233. Put all the files from that mod in the Skyrim folder except d3d9.dll (you already have d3d9.dll from ENB), along with the ENB files. Then edit enbseries.ini (at the top):
[PROXY]
EnableProxyLibrary=true
InitProxyFunctions=true
ProxyLibrary=d3d9_smaa.dll
Thanks for that.
Should i disable SSAO and DOF with SMAA? Or can i leave them on?
Thanks.
