Carbs means it's none injection basically and use carburetors to suck in and distribute the petrol in the engine. There's nothing wrong with carbs and nothing wrong with fuel injection, just different ways of mixing the fuel, simple as that. All Honda CBR600's upto the CBR600Fi (which is around 2001 ish) were carbs... then they switched to injection and at the same time changed the bike design a little to the "fox" styling on the front i.e. it was pointy and more modern if you like that kind of thing. However, there's very little different between the CBR600 FX/FY (1999/2000) models... engine wise and the later models, it's basically the same bike, all on alloy frames (pre 1999 they were heavier steel frames and the fairings went right up onto the tank).
Go for a 1999 model onwards and it'll be basically the same bike as the later models through the early 2000's... just looks a bit different... the Sport didn't have anything done to the engine, just had the changed seat and removed the centre stand et... nothing to make you want it more than the none Sport though...
Upto you... like I say from 1999 onwards, these bikes go for solid ones for around 1500 upwards...
For me, I did around 900 miles+ on the 125 while I was on a DAS course so I felt it was time to go bigger and needed something bigger for motorway traveling etc... would I have jumped straight to a 600? probably... whether I'd have done the mileage or not... as I want what I want? is that sensible? Who knows, define sensible
It couldn't really be easier unless it had a set of pedals on it.
