Tried PA today
Was ok but kept getting Gmail fc so back to omega 26.
That is one of the bugs, but I don't use the Gmail app. The fix is to set it to 720px.
Tried PA today
Going back to CM10 nightlies after a few days with PA. It's an awesome rom, but the novelty of having tablet ui apps has worn off![]()
Yes i've got that with mine. fantastic little box that i carry around with a fully charged spare battery. Swap the batteries over every now and then and plug it in to charge overnight. (means that i'm not charging the batteries as often, which will hopefully make them last longer) You can get a micro usb splitter that will allow you to charge both the phone and the spare at the same time.
If you do get a splitter how would you charge bothe the phone and battey at the same time?
Where would you plug the spare battery in? Also is this an origian Samsung battey?
I don't consider it as a novelty as it same as CM10 but with more control. You chose where to have tablet UI, for example if you don't like the split view in the settings, you can just increase the DPI for settings app and its back to normal.
You split the micro usb, one end goes into the spare battery charger, the other goes into the phone. I think mobilefun sell a micro usb spitter cable that would do the job. (i just use 2 cables if i ever need to charge both, which is very rare as i'm usually discharging one whilst the other charges) The other useful point is that you will be charging via the box more than via the phone so you are less likely to damage the micro usb port on the phone. (£16 for a new charger unit is a lot cheaper than getting the phone repaired)If you do get a splitter how would you charge bothe the phone and battey at the same time?
theres some dumb people about... and they bought an s3 box for £152 lol, item code for the bay.. 280974184091
It's Jellybean and it's official. Gallery is smoother now
That listing also describes the item as a phone that is sim unlocked in the detailed section. Ebay should remove items like that.
Plugged phone in and it isnt saying theres an update in kies?
Lets see if it's fixed the poweramp issues if they're gone then I'm in!
Once Wanam releases his version
