Good work![]()
Thanks guys. That was actually the second set of 3. Monday will be 5. Slow and steady.Only 3?!
Good work![]()
Hi guys, I need a bit of advice please
I used to train pretty hardcore during my college and uni days days, say 2001 up until 2008 - mainly weights, cardio just for warm-up/cool-down. But then I lapsed once I got a job and became fatter and lazier and less than a year later I slipped disc (L1/S5 or L5/S1 I can't remember which way round) and had to stop altogether.
Anyway, after a few years of being out of the game I feel like my back muscles are finally strong enough and fancy getting back into my power training and will be purchasing a power rack and bench.
Of course I will start slow and keep my technique as perfect as I can (need to dig out Arnies encyclopaedia again), but I was wondering if anyone else here has come back from a slipped disc and what precautions did they take or did they buy any special supports or equipment?
Cheers![]()
After back problems you are probably going to have to completely rethink how you approach core training. It's highly likely (almost certain) that your movement patterns are faulty, which means that even doing core training as you normally would might aggravate your injury.
Do you have any more details of your injury?
There is plenty of material to read in the exercise guide thread (look for "core" near the bottom of the first post), but in general, you want to be encouraging stiffness in your lumbar and avoiding exercises that promote movement there. You will also need to pay attention to your spinal alignment 24/7, including when lifting. If you are moving around in extension or flexion then you'll run into problems (such as the one you currently have).
After my wedding I'm allowed to "get bigger"
Sounds like your fairly eager to get going!snip
Core wise, I think I'm at a stage now where I'm strong enough to start back on the big stuff... we'll soon see.
Thanks for the advice![]()
It's important to know that the "big stuff" is still basic core training. The biggest and strongest guy I know (international level powerlifter) still does the stuff I listed in the exercise guide.
Teaching your core to work properly first will result in more strength down the road.
There's no reason you can't also be squatting and deadlifting (great videos in the exercise guide) at the same time, but be careful.
Oh, and you should have no use for a belt. Belts do not prevent breaks in posture.
