- 24 Jun 2008
I'm brave I installed it straight away
Er, so what does that do then?
Just installed the sim update, not noticed anything that has changed.
Just installed the sim update too... Can't see anything obvious.
It's a change to the wizard that runs when you change sims.
You will only see a change if you take your sim out and put a different one in. Told you it was a rubbish update
On a positive note the major update is great! I get better signals, wifi and mobile and the browser definitely seems to render pages faster. 2.31.401.5 here.
Usage was much heavier i.e. well over a hour of browsing (had multiple browsers installed trying them out and uninstalled the ones I wasn't as fussed on, hence why only quick ics browser is showing
Great outcome in the end and certainly well worth pursuing! Thumbs up to HTC and the retailer for sorting that out
Only ever on the mobile for like a max of 5-15 minutes each day if even that, use text/whatsapp etc. mostly
