1.2v is the safe limit for vccio or cpu/vtt,
latest beta bios for up4 th F9a
http://www.mediafire.com/?d3dt6cb6rf7fg95
2133MHz 10-10-10-28 1N at 1.4V here.
Does exactly what OCUK claim, amazing memory.
Right I'm still having loads of problems I really cant get much of a clock out of these.....
I have tried 2000mhz at stock timings with 1.6v and 1.1 VIT, 1.0v IMC.....buts still getting errors on prime straight away....
Any ideas? I'm on the latest bios for my board...
try one or two clicks more dram and or cpu vtt voltage,max safe vtt is 1.2 and dram you can use upto 1.65v more if needed but you shouldnt need that much
I've been trying to OC my Green, but it seems to default back to 1600MHz.
I've set the timings in 3D BIOS to 11 11 11 28 at 1.5V VDRAM, and when I select 2000MHz, save and close, it posts as 1600MHz in CPUID. Any pointers gratefully accepted!!![]()
I jumped on this bandwagon, bought 8Gb to use with 3570k, GA-Z77X-UD5H.
i ran super pi at 9 9 9 24 2133 and it worked fine but after trying to go further and failing i now cant go back to my 2133 speed even after a cmos reset.
Any ideas?
