http://forums.thewarz.com/showthread.php?26997-I-have-to-give-MAD-props-to-the-development-team
Looks like there was Grave.
awesome cheers mate.
i was looking but that forum is so busy its hard to keep track...
ffs still crashing like mad for me after that so called patch...
poxy devs, alpha or not its shocking...
Some people forget what Alpha is:
"Alpha
The alpha phase of the release life cycle is the first phase to begin software testing (alpha is the first letter of the Greek alphabet, used as the number 1). In this phase, developers generally test the software using white box techniques. Additional validation is then performed using black box or gray box techniques, by another testing team. Moving to black box testing inside the organization is known as alpha release.[2]
Alpha software can be unstable and could cause crashes or data loss. The exception to this is when the alpha is available publicly (such as a pre-order bonus), in which developers normally push for stability so that their testers can test properly. External availability of alpha software is uncommon in proprietary software. However, open source software, in particular, often have publicly available alpha versions, often distributed as the raw source code of the software. The alpha phase usually ends with a feature freeze, indicating that no more features will be added to the software. At this time, the software is said to be feature complete."
Hope that clears up the crashing points![]()
But wasn't the game in Beta?, then it went alpha, and it's only a few weeks away from beta again
Also this amount of players are more likely to find bugs than a few 100 at a couple of expos.
Got bitter about being killed so doing the 'friendly' followed by whack to the back of the head with a torch can't stop laughing
But wasn't game in Beta?, then it went alpha, and it's only a few weeks away from beta again
"Alpha
bore off...
they knew it wasnt ready, but like other people in this thread has said they rushed it out before dayz standalone simple, i dont even like dayz either but its clear to see trhats what they have done...
Cool story bro, stop crying cause yours crashes. Teach you to buy into Alpha's expecting a bug/crash free game.
wow peeps still say "cool story bro".
nice one you must be so proud of yourself with your posts.
i knew it would be sketchy, but not to the point i cant play for more than 3 mins max a time.
why dont you post a meme next time...
