Ouch, what happened? I have plenty of time to be very delicate with it, my razor blades can take idividual layers off your fingers, should be nice and sharp. Guess I will have to try and soften up the glue with a hairdryer though.
I think it will be very hard to sell a de-lidded one in a few years - this is what is putting me off, not really worried about damaging it. Seen some really brutal jobs of it on youtube lol.
Did you mean conductive? According to the AS5 website AS5 is actually really non conductive. This shocked me to learn since it nearly killed my X800 PRO.
http://www.arcticsilver.com/as5.htm It's on there.
Question: Is it hard to break through at first? I was thinking of doing this with a safety razor blade. My feather blades are very sharp, is it like cutting through metal or is it a bit softer?
Arctic Silver 5 should be kept away from electrical traces, pins, and leads. While it is not electrically conductive, the compound is very slightly capacitive and could potentially cause problems if it bridges two close-proximity electrical paths.
As for lapping surely a risk free process to do whilst the lid is off
Surprised no ones doing it at the same time
Why would you want to lap a lid that you weren't using?
What was done on the old Athlon's? you're talking about the ones with the 4 round spongy pads right? I thought they were already nekkid. The core was so tiny as it was.
I thought about this but I am a clumsy oaf, so it's a no noWell done for being braver than I
3930K is sandy-e isn't it? So it should have been soldered?
