Caporegime
- 18 Sep 2009
- Dormanstown.
Don't think there is a way, the "keyboard" isn't selectable.
And I only said about exit, which there is none, to end the app you have to do the sloppy method of going to desktop and then dragging it from the left and then dragging it down, there's no animation transition dragging it down, one second it's there and the next it pops down for a second and it's gone.
IIRC if you drag down from the top of the screen to the bottom it will close the current app.
.The W8 way of "killing" app's is sloppier, if it had a better animation and transition it'd be a lot better, most people won't know how to do it when they first get the tablet, the lack of animation would give the impression that nothing's happening.
Plenty of games can be closed on Android, they have an exit button.
And the same with the majority of applications I've used.
Say I run Fifa on my Xperia Play, I can exit the app through an actual exit option.
And even on an app that doesn't, I can set android to kill the application if I press "back" and "back" out of the app, can also set it where if I hold "back" it'll kill the app.
And even if there wasn't, to kill the app, I'd just bring up the app's currently open (Which is just one button click to bring up), and then slide to kill them (Which has a very smooth transition and animation that's lacking with what I've used of W8)
Great launch Microsoft :grr:
They've pushed my preorder date back a week from 26/10 to 2/11. Overpromise and under deliver.
You might be alright, they might be holding back web orders to ensure they have them in stores.
Annoys me though when any firm promises specific dates, then put them back without any explanation - it's just not good service.
What tablet are you running on (is it even a Surface?) and what version of Windows? MS have released a pre-release patch which includes improving the behaviour of the drag down.
However it's a change in habits, there's no benefit in closing them down as has already been said. You can also close them from the left hand bar, right click close, and if you have a keyboard ALT+F4. Some apps will no doubt have an exit option.
For all those who have had pre orders delayed, I'd be pleased that Surface appears popular enough to have sold out in a week. Kinda silences all those people who say its going to flop.
