Windows 8 who's buying/upgrading
is it correct that the key is included in the disc? so it will have to be 3 different downloads for each pc, i cant just burn one disc and use it on all 3?
Yep, allthough there is a way to change them, but don't know anyone who's tried it, using command prompt. If you have a decent connection it only takes a few mins. Or went to sort my parents computer out and it has ~11hour download time, so came home and going back there tomorrow.
Don't think so. I had to type the key in during the setup.
Odd I'm positive I didn't type it in. Be brilliant if I have just got **** memory though.
So just to check I can just install windows 8 CLEAN INSTALL without bother even if I purchase the 'upgrade' version ?
What do you mean clean install?
You can't install it on an empty HDD, you can however have, say a drive with win7 on it, run the upgrade assistant and then chose the save nothing option.
people seem to have installed on fresh drives.
yeh i was thinking more about time burning dvd's etc :) cheers tho, might try usb.
So I can use the upgrade version even if I don't already have windows? got windows 8 RTM on a desktop PC no other OS on it?
Maybe, several of us have upgraded from PR with no issue. However if you have no valid license to upgrade, then it's not really legit.
I have just installed a clean copy of 8 x64 pro and it all went well. But is there a way to pin to the start menu any of the Steam games I have installed...?
I have only got Civ V installed at the moment but even though I can create a shortcut on the desktop I can only seem to see and create a pinned icon of the Steam client itself...?
