ok the Windows8-UpgradeAssistant have downloaded a ISO but how do i know if is a pro or non pro version?
The online upgrade is only the Pro version at the moment.
is it correct that the key is included in the disc? so it will have to be 3 different downloads for each pc, i cant just burn one disc and use it on all 3?
Odd I'm positive I didn't type it in. Be brilliant if I have just got **** memory though.Don't think so. I had to type the key in during the setup.
So just to check I can just install windows 8 CLEAN INSTALL without bother even if I purchase the 'upgrade' version ?
What do you mean clean install?
You can't install it on an empty HDD, you can however have, say a drive with win7 on it, run the upgrade assistant and then chose the save nothing option.
yeh i was thinking more about time burning dvd's etcYep, allthough there is a way to change them, but don't know anyone who's tried it, using command prompt. If you have a decent connection it only takes a few mins. Or went to sort my parents computer out and it has ~11hour download time, so came home and going back there tomorrow.
cheers tho, might try usb.Odd I'm positive I didn't type it in. Be brilliant if I have just got **** memory though.
Did you run setup from within Windows or boot from a medium?
people seem to have installed on fresh drives.
b.
Within windows
So I can use the upgrade version even if I don't already have windows? got windows 8 RTM on a desktop PC no other OS on it?
