YOUR BASKET
1 x Intel Core i7-3930K 3.20GHz (Sandybridge-E) Socket LGA2011 Processor - Retail £459.95
1 x Gigabyte X79-UP4 Intel X79 (Socket 2011) DDR3 Motherboard £209.99
1 x Seasonic 860w '80 Plus Platinum' Modular Power Supply £169.99
1 x Corsair Obsidian 650D Gaming Midi Tower - Black £149.99
1 x Patriot Viper "Black Mamba" Generation 3 16GB (4X4GB) DDR3 PC3-17000C11 2133MHz Quad Channel kit (PV316G213C1QK) £99.95
1 x OCZ Vertex 4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (VTX4-25SAT3-128G) £92.99
1 x XSPC RS240 120mm Radiator - Black £38.99
1 x EK Multioption Reservoir X2 250 Basic £33.98
1 x Bitspower Premium G1/4" Black Sparkle High Flow 7/16" ID (5/8" OD) Compression Fitting £8.95
1 x Mayhems X1 UV Oil Black Premixed Watercooling Fluid 1L £7.99
1 x XSPC 7/16" ID [16/11mm] High Flex Hose - Clear £2.99
Total : £1,292.26 (includes shipping : £13.75).
I thought we established yesterday that 3930K + mediocre mobo is better than 3770K and a 320quid mobo...
Swap out PSU for XFX or corsair to save extra 90 pounds...
Ok thanks i just dont liek to compromise mobos as they are a lot of effort to upgrade where as a cpu is an easy swap! everones said amazing things about that PSU so ill leave the xfx and corsair i think
That Cinebench I showed you is much better than I manged with a [email protected] which got 7.78
And I think the motherboard I selected looks nice, has the IR3550 powerstages as its part of the UP range and has eight dimm slots for more RAM later.
ill take a better look at the mobos and see whats there
