- 19 Dec 2003
- UK
Hi folks,
Does anyone have the problem where their 'first' upload always fails?
Sometimes I try to upload a file on a website which has a 'browse' then you select a file from your computer, press upload, it fails a few seconds later.
But if you do it again, it then works?
I can't see what kind of setting that would be? But coming from a Belkin router, switching to the 7800N it has happened (never happened with the Belkin).
I am using it on a wired connection, latest firmware (1.06g).
Thanks
Thanks
