easier to just replace a skin within one of the trailer pack mods.
just downloaded the fuel station update and ive ended up with a UKash virus on the pc, just be carefull with these sites guys they seem dogeywas just about to do some trucking aswell
and how are you saving your .dds skin?
.and you're just dropping your dds in the mod scs?
No Im replacing
I used to play some of the older trucking games by SCS, I think 18 Wheels of Steel was the last one I properly sunk time into. It has to have been nearly 10 years ago since the first one I played.
So i've downloaded the trial of this one!
What essential mods should I grab? and what page was the config for using an Xbox pad in a decent way?
Cheers!!
With the exact same name?
try putting your design in place of all the different company names in the scs mod, will be easier to see it then when driving around.
but you say Voorhees tested your skin in his game and it worked?
Get him to send you the scs mod he put your dds in and then If that doesn't work then I have no idea.
Cheers!!
