***The Official Nokia Lumia 920 Thread***
  • Thread starter Thread starter RSR
  • Start date Start date
So, seems I've missed a bit.
The Cyber port shop seems trusted?
Deffo works for UK networks?
What's the £ from euros?
Yes - It looks to be trusted, from what I have read.
Yes - Its sim free
See above.
EDIT: You can also email them in English and they will reply.
:D
I am guessing if you ordered from cyberport that you realise that it could well be almost 2 weeks before you get it from them as it says "expected in 3-10 days".
So I assume it isn't the time that is the issue but the availability.
Shrewsbury P4U say next Friday,
There is no way I would buy it without playing around with it first though, they have a dummy model, but that doesn't help with anything other than the size.
Do they normaly have models to play with in P4U?
I normally avoid going in there as they tend to pounce, like you used to get in Dixons.
According to Phazeshifterz, That is a standard email.
My local EE store had a functioning demo unit, but the battery was dead when I went in to try it :(
To be honest if they pounce just say you're interested but you would like a few minutes to play with it yourself then just walk off before they come back
I happy to tell them I am browsing, I just don't normaly need to go in there, there an EE store in Telford, I will look if they have a live unit tommorrow.
I don't expect they will.
