Hey all, ive had this phone now for 4 months it is stock, no root and on JB and is an unbranded handset and tho I am happy with the phone in general, I have had 2 annoying problems intermittently. The 1st is that randomly I find out that I cant recieve calls or texts so I try to call and it says "not registered on network"
So I reset the phone and this cures it. I have only had this happen 4 times in the time of owning the phone but it is annoying as it shows signal and everything. The sim card does work as ovbiously in the 4 months ive made quite a lot of calls and texting.
Also I have to reset the phone every couple of weeks as I end up with the bluetooth not working on the phone and sometimes the network stops working both wireless and mobile data, so im guessing the radio's are crashing in the software and a reset cures them. Anyone else have these issues. Thanks.
Do you have a Sim Free International S3?
My S3 seems to have lost the ability to open youtube links on the browser with the YouTube app is this something jelly bean has changed?
Is there anyway I can change it back so I can open youtube links with the app?
Leave it with me... My lift just turned up for work
I will be back but probably tonight :/
I assume so, I bought it as Sim Free but not sure about the international bit. It's i9300 though. Why do you ask anyway?
About the call log thingy...thinking about mine, it's possible the calls have been grouped in in chronological order, not specifically by contact. Also when i try and change the view mode from 'all calls' to anything else it always reverts back to 'all calls' once i leave the screen. Must admit i do prefer android to ios overall but ios doesn't have (many of) these little traits. Maybe its cause of all the flashing roms.
i just find it strange that it groups a few then it will add a new instance of the same contact if i cal them again
