Mine is just barebones, come with a wooly mitt and that's it so I can go out and get my own pads, backing plate etc. I'll look into the P1, would you recommend the 3m pads then?
It was £44 at Argos believe it or not, £43 direct from Silverline but £5 p&p with them, free collection from Argos![]()
Yeh the 3M pads are thoroughly decent - just that cheap backing plate which i stupidly bought instead of a good one. The 3M backing plate are meant to be among the best too. I bought my Silverline, with 2 free polishing pads (they were doing a deal), 1 x 3M green compounding pad, 1 x 3M blue finishing pad and a crappy backing plate for £68 inc del from EliteCarCare. There's also a detailing world coupon you can use to get 5% off i think.
