Obviously don't worry about dropping the bar if it is going to cause problems but if can do it remember what we said when you came down about hip hinging. You want to pull your hips back while keeping the weight on your heels and the bar over your feet with your back straight and your knees back.
That's also how to do perfect RDLs, just keep the bar on your legs and your back straight, easy
Core work looks pretty good, but a few more ideas for some harder exercises:
- This will rape you but if you can do them they are fantastic. The whole idea is to get maximum tension to stop you lower back over extending. If you can't do full range reps try doing a small wobble up and down and then performing a plank as normal, the addition of instability in that way will add a massive difficulty multiplier
- I know you are aware of roll outs but I find them invaluable so I'm going to post them anyway
- I also know you have very limited equipment but bear in mind these principles when working out progressions from simpler roll out type exercises.
If you don't have an ab wheel you can use a ball, like in the video, or a foam roller and just walk you hands down it.
Also look up Valslides, they are stupidly expensive but you can just buy some furniture sliders from amazon for about £8. They will make body saw a little easier to do and they are also very useful for other exercises.
Deception, you are more than welcome to come down any time. Just email Ice and we can sort it out
Edit; Delvis, minor point but tuck your chin more and keep the chest up
