Since youve been loyal ask them to swap it out its not even old, it does seem dodgy i would NOT be happy with that at all.
Since 22nd October. I was about 5 days outside the 14 day when I noticed that my temps weren't exactly par for the course.
Thats why I do my testing as soon as, I get my component.
My idle and load temps seem quite hot. I had assumed this was normal until reading some other people's temps for the same card (or other OEM brands). I have a full tower case with good cooling so I wanted to find out what temperatures are considered normal for both stock and overclocked use to compare mine to.
Some people are giving temps of"max temp 64c, 1250\1250 1.25v 47%fan" whereas I get higher temps at stock with higher fan speeds running the same benchmark.
Obviously, you would need to test the card yourself to determine a fault, but to avoid wasting my money and your time, if you could tell me what temps you consider normal for this card and in what test conditions, I can replicate them at home to determine if it's worth an RMA.
My reference cooler 5850 ran cooler and quieter with a hefty overclock and 2 years of dust in it, soI guess I was expecting more of an aftermarket cooling solution. I'd be happy to provide some afterburner screenshots if that helps you determine a fault.
Thanks for your time,
Dev
Graphics cards can run up to about 90c before they start to fail. I would recommend you run heaven benchmark and furmark on extreme settings and also run MSI afterburner in the background to monitor GPU temps.
Regards,
Luke Pointon
That response is totally unsatisfactory. The issue isn't will the card fail, but does it fit it's description - i.e. aftermarket cooler for lower temps, quieter operation and overclocking headroom. I fear with someone like the guy who responded to you checking the card there would be no chance of a successful RMA.
5UB is usually very hot on customer service so maybe send something his way.
Wondering if I can RMA the card and if no fault found rely on DSR so they don't return it to me. That way if fault found they pay postage, and if no fault found I only pay for it one way (i.e. back to them and they keep it).
YOUR BASKET
1 x Gigabyte ATi Radeon HD 7950 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games £259.99
1 x HIS HD 7950 IceQ BOOST 3072MB GDDR5 PCI-Express Graphics Card (H795QC3G2M) with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games £227.99
1 x MSI HD 7870 Black Knight OC 2048MB GDDR5 PCI-Express Graphics Card £179.99
Total : £679.97 (includes shipping : £10.00).
Its time to choose.
Its a shame that OCUK dont have his iceq x2 7950 any more...
YOUR BASKET
Its time to choose.
:O the x2 is gone? That didnt last long then...Kinda liked that card imo
Id go for the WF if it was me...but that was £239 a couple days ago now its gone up...
Yeah, I enquired further with another webnote, asking for specifics, and was told "if the card is too hot or too loud we will process it through". Again, I feel the point has been missed. If the card is "too" any thing it is clearly faulty so what good is it telling me that? I'll call and ask someone tomorrow on my lunch. Perhaps I'll be able to explain it more clearly.
Post in the customer service section, ask for Bailey and or 5UB, they sorted me out with the X2s. I took the cards in for a straight swap and had a chat with Bailey while they swapped them over in the warehouse.
Was a very pain-free experience.![]()
Why did you swap your x2s?
Yeah, usually 5UB answers the threads, but this time it was someone else. I may have another go in there.
I titled my thread "FAO 5UB" I also sent him a trust message about it too.
I personally think you will be lucky to get an RMA with the card. They will probably test in a test bed (open air, so lower temps) and if the card runs all tests with no crashes or artifacts it will probably be deemed as not faulty. A DSR of course would be ideal, but you are out of time now is that correct?
I wish you all the best with an exchange of course, as no-one should be left with a card they are unhappy with, hopefully 5UB sill sort you out. If you get your card returned though I would recommend replacing the thermal paste with some quality stuff, and reseating the cooler. This seems to drop peoples temps a decent amount. good luck![]()
