- 1 Apr 2009
whatever, just don't bring your hacks in coop.
all quests should be soloable
Well they aren't and probably never will be, so either deal with it and don't do those quests/bosses solo because they are DESIGNED to be dealt with by groups or ask on here and join up with any of the other dozen people looking for help.
Doh!! I did the TK Baha side quest and handed it into Hyperion by mistake instead of his niece!!
Is there anyway I can edit the quest in the save file and start again??
Edit!!
I managed to find a save editor. I managed to edit the save file!!
Edit!!
Any try this:
If you're on the PC you can go to directory of the game then go to DLC, then premium club, then open the WillowDLC.ini with Notepad and edit it to:
[GoldenKeys]
+SourceId=254
+NumKeys=300
[PromotionalUnlocks]
+UnlockId=2
this will give you around 260 keys to use at your will
you did the right thing.....she gives you nothing, in the 1st playthrough she gives you a rubbishy old pistol, the Hyperion weapon is better but not by much... it's a shotgun that fires like a wave, it's a very odd weapon.
Hasnt worked for a long time. There's only one way to do it now.
Lolwut?
The shotgun is terrible. Its no better than it was in the first game, because the wave pattern just isn't a useful spread. The pistol on the other hand gets a massive crit damage boost and is a great mid-range weapon.
Of course, if you've cheated and opened the chest 200 times of course its going to seem bad
@ CAT - Its a bit late now, but if you do hand a quest in to the wrong person you can just press Alt + F4 and it quits before it saves.
I keep hearing about arenas - what are these or where do I find them?
You needn't download anything, and tbh doing so is just inviting malware. Its possible to just edit a file to allow keys to not be redeemed when used.
you have to download this weapon cheat, it works fine, search for the video on Youtube.
but it keeps giving you the same stuff over and over again, it wont give you Legendaries, only high damage normal guns, these you wont find in game, so it's still very good....it looks like about level 55
am i Cheating ?....... no, it's now the correct balance for a FPS, it's one head shot or two body shots, in fact; the game is way better now, it's much more skillfull and fun, because i still die easily and it's important that you do. because altering your skill points/ God mode etc will spoil the game totally, dont do it
Sledge's ****ging bitch is probably too powerful, especially with the 24% **** damage relic, it's killing them too easy at range, roughly 100ft, it's deadlier than Conference Call, in fact, i have no need for Conference Call any more, i only shoot Bandits nowadays..... this gun is NON- CHEAT, just in case someone has a go, it's a legendary.
Bit late for that advice, I think he's dl'd malware several times already ^^
Mal, go play a different game. Seriously, you'll be much happier.
And Level 55? What are you on about?
Just finished the game - BL2 is much more darker than BL!!
However,I only got one legendary(the one from Lilith),is this normal for your first playthrough?? My character is level 31 and I did quite a few side missions.
Edit!!
I do hope they explore the originals of Handsome Jack a bit more!
Interesting scar on his face!
i then noticed Juggernaut, plus the huge Psycho ( long arm) and also Goliath have staples holding their faces on....... Goliath's staples explode and his head pops out and a bandit sais ``who removed his helmet, quick dive for cover``.
