Only had the one quote so far for installation, will get more, but does this sound expensive?
904 grade liner £1200
Insulate chimney liner £350
Supply and fit new chimney pot £50
Scaffolding £300
So that's £1900 not including a stove.
scaffold seems cheap enough , but the liner!!!
I would quote around £1200 including the insulation (if it is a normal 2 storey house)
Why do you need a new pot?
What age is the house?
Often you don't really need flue liner, I haven't used it and chimney *seems* fine, think about it, the chimney was built to do what the flue does.....
snip
	Just got done installing my log burner for the winter, just a little 7KW one.
If you using an appliance that is designed to run with the doors open then you must have at least 300mm in front of the stove.
Not true!
Hetas rules state that if it is not clay lined and you are fitting a high efficiency burner you must fit a stainless steel liner in the stack to conform within guidelines as the gases and condensates can attack the mortar in the flue leading to leaks.
It is worth noting that woodburners do produce a certain amount of carbon monoxide (and we all know how bad that can be)
See here:
http://www.dailymail.co.uk/news/art...wood-burning-stove-leaks-carbon-monoxide.html
 but I only use it mainly over xmas and chilly winter evenings.Some nice burners and fire places in here!
Don't have one myself but my friend put a burner in a little while back. Completed the work all by himself including the plastering which was a recently acquired skill - his progress pictures are below:
Also, re: the TV comments. Another friend has a TV mounted in a similar position. Yes height is probably not ideal but heat isn't an issue since there's a large enough mantle.
You can actually feel the cool zone directly above the mantle where it deflects the fire's heat forwards.
gt
EDIT: Oh and here was the flue liner going in...![]()
Shaz]sigh[;23354401 said:(I think) You can use a double skin flue which could be punched out through the roof. I believe I've seen them on the side of houses before but they look awful...
