Big 400, congrats. Form wasn't the best, but not "that" bad. your setup was already wrong from when you started. Make sure to stick your arse out and have your back straight when you position yourself to start the lift. I'm sure ice can write a whole paragraph to exemplify further.Had some fun in the gym today...
mrthingyx ------- 95 / 135 / 170 ------ [93] ---- 400kg
It wasn't pretty, but it still went up.![]()
Update!!
160/210/270(s) - was 128kg this morning so might as well update that too![]()
Big 400, congrats. Form wasn't the best, but not "that" bad. your setup was already wrong from when you started. Make sure to stick your arse out and have your back straight when you position yourself to start the lift. I'm sure ice can write a whole paragraph to exemplify further.![]()
) - bum being too high and back not tight enough are just two points.
Should get 135kg for reps on deadlift tonight, may go for a 1rm on Saturday, not sure yet.
If I can do it with form as bad as mine, then you should be well away!
170kg in the bag?![]()
Stop messing about Delvis, stick 140 on and be proud of deadlifting 3 plates a side!
HAH! No
No idea mate, I rarely try for physical 1rms as I'm prone to breaking as it is let alone putting my body under abnormal stress
Saturday Delvis, deads is gonna happen big time.
Hey man, thats 4!
Delvis looking at the 130kg for reps video you easily have 140 in the bag. I pulled 140 for a single when I was nearer 115/120 for 5.
How can you say that when you can triple 130kg? Clearly that's showing your back is more than capable, it's just excuses man.
