As long as he cleans it off properly and returns the card to bone stock, there shouldn't be an issue.
Tomorrow is D day Petey.
You've got two chances of me doing a build log, fat chance and no chance.
The only log ill be doing in the next 24 hours is on the toilet with a copy of the sun. It won't be a mini log, thats for sure.
Let me know if you want any photo's of that.
EDIT
Btw i decided to avoid the tape and go with the Arctic glue stuff.
Matt u need to ring me and we can talk each other thru it! I'm bricking it badly cause if I ruin my card ill be so bored without bf3 over Xmas lol![]()
Cheers for the links bud! Gonna do mine tomorrow night and let it set overnight then get it all up and running sat morning!
Hmm tempted aswell could always do it in afternoon! Go watch hobbit and come back and play with it! Keep us updated on here tho bud! Be good to see how u get on with it!
Question.
Where do you we put the clear plastic strips? That's the only part im not clear on atm.
Never did work that one out to be honest. I know they're there to stop metal on the sinks shorting against metal on the PCB, but couldn't really see where they were meant to go. Can't actually remember if I even fitted them in the end, so probably not that important!
The clear strips go against the edges of the chokes on the PWM's. There are metal contacts there that can short if you have a heatsink against them.
This guy has done a video that might be helpfull...
Using a decent rubber on the Ram chips and Vrm chips is also very important as the stock heat pads leave an oily residue.
That's it. That is the only place I put the strips and as far as I can tell the only place they are needed. I put a strip on the choke side and a strip on the other side just to be safe.
