Thanks Greg.
Annnnnnnnnnd it works. Thank god!
Was a real pain in the ass though, wasn't helped by the fact i had almost no adhesive on the washers. Such a frustrating experience.
Then screwing it all together at the end was equally annoying, needed seven pairs of hands.
On to temps. Played far cry 3 as that used to get my overclock of 1125/1719 up to the 80c range on both the core and memory with a fan speed of 50%.
GPU went up to 59c at 100% fan speed which was almost silent. Kinda like a quiet case fan. Memory was at 80c.
Pretty good i think. Wish the memory was a bit lower, but farcry 3 does heat up the gpu more than most games once you used that compute HDAO.
Now for sleeping dogs, that heats it up even more.
I guess I could keep it as a back up, but my EVGA GTX 680 runs like a dream
Mine runs at %50 constant. I cannot hear it and it remains under 65.c in any game.
They are superb coolers.
Its silent up to 60%, and even after then i can barely hear it. At 100% its like a quiet case fan running at full speed. I'm impressed.
Black ops 2 zombie mode vsync off
GPU 52c
Vram 65c
Good stuff Matt. How bout dem VRMs?
Slightly off topic, but it's so nice to see a thread reach page 4 with nothing but positive, helpful, friendly posts and the kind of spirit that makes this a great forum.
Back on topic, well done on getting the cooler on and in getting such great temperatures. Nicely played, sir.
Vrm cooling is definitely the weak point of the cooler.
My reference vrm cooling was better.
But this has superior core cooling.
I'm still experimenting whats best tbh.
There is no way i can take the card apart without starting again from scratch, at the moment im reluctant to do that as i have no adhesive for the washers or the heatsinks.
Maybe better heatsinks on the VRM's will help.
For now ive added two 120mm Spectre Pro fans as exhaust on the side of my 600t. This has brought the vrms down a bit.
If i run at stock volts 1.112, then the vrms don't go above 80. That's worst case scenario as well (sleeping dogs, SSAA) with the memory at 1719 stock volts. However any bump in core voltage seems to affect the VRM temps, whilst the core remains the same regardless.
I saw your post Petey about the extra fans you put around yours. Its a good idea, not sure how id get my fans in place like that though.
I'm very happy with it, but im not totally satisfied with the vrm cooling at overclocked volts on the core.
I'd like to keep it below 85c if possible.
Whacked the voltage up to 1.225, core at 1250. Stable as a rock, core nice and cool. VRM 100c, i backed out there. Core was around 58c.
With the two fans ive now added i expect that will come down a bit, but not enough for my liking.
