I don't think ill damage it by reseating the heatsinks, the G1 stuff comes off pretty easily it seems.
I'll just use the rubber/alcohol on the vrms to clean them up then use some thermal tape to re-apply.![]()
But what are you going to achieve ?
The tape could even be thermally worse than the glue so you could end up with worse results.
