I flashed this a few days back, my Gmail notifications don't work properly now.
Going to flash the new one and see if that makes a difference.
Didn't have a problem on 9.0. Just about to flash 9.1.1 so I'll see if the problem is there too
Guys in need of much needed help! I currently have the S3 16GB but I have games around 2GB taking up too much space so I wanted to purchase a SD card for the phone.
What do you lot have and for how long have you had it?
I ask the second question as I've been reading that A LOT of Class 10 Sandisk 64GB cards are failing and after a while not bieng reconised by the phone.
I wish samsung would hurry up and release the 64GB model of their SD card.
What do you have and what do you reccomend and from where?
And will it allow me to put my android games onto the SD?
Cheers.
Didn't have a problem on 9.0. Just about to flash 9.1.1 so I'll see if the problem is there too![]()
Cheers.
Good to have so many options though. I liked how JB Dom was part of the installer.Trying out this crdroid 9.1.1 atm. That was possibly the longest set of install screens on an aroma installer I've ever seenGood to have so many options though. I liked how JB Dom was part of the installer.
However I'm not liking the AOSP lock screen, but really can't be bothered to reinstall it all again..
The remaining steps will let you to install or uninstall anything that you have already installed and for some reason didn't like it, without need to install FULL ROM again.
Im having no problems at all. Its nice and smooth and as others have said you have dozens of options when installing it. The sound mods are nice, music is better.
You will need to wipe as its a different rom but do backups as normal incase you dont like it.
I found that on a clean install connect your phone via wifi, then log into google play via pc and you have all the apps that you have installled on your phone. Then click the ones you want to install and use titanium to restore the settings, doesnt take long. I know you can restore apps as well but i find it reduces errors.....but thats just me
Im also using jkay version of jb domination, you need to buy the app to change the settings but it was only £1.50.
This app gives you more quick toggles on the Notification bar! A new customizable Quick Launch panel on the Notification bar. A customizable Phone Dialog. Two new customizable lock screens... and more! Some people call it: Full control!
https://play.google.com/store/apps/details?id=com.jkaysoft.icsdeluxe&hl=en
You need the framework installed first but it comes with jb dom, make sure you get the right one as there's 2.
Just had this new android update and wondered if anyone else had? For me it has rioned the keyboard as I now dont get the question mark and comma etv after typing each word and insteqd get the and similar words? !?! Anyone know how I can set it back to the old style?
Alex
Ive used the 64GB SanDisk card since release and not had a problem so I'd risk it and purchased one tbh..
Ok thanks, which one did you buy abd which would you recommend?
There are the sandisk ultra, ultra mobile or the ultra andriod bi-coloured? All are class 10.
