Enabled XMP profile just now and here is the new qpi voltage etc.
Now I will need to play some far cry 3 etc. to see if it happens again.
Wow!!! You use a lot of memory
If you are going over the 8GB, it could be that which is causing the issues. Give msconfig a look and knock off a few processes from start up that are hogging resources.
No idea as to why that much is being used
, most I have ever seen is at least 5GB and that is with BF 3 running
i.e. this is my usage now:
Had a look there and there isn't much that starts up, just the usual stuff, firewall + AV, peerblock, CCC, unified remote, awaremote, realtek sound drivers, fraps, radeon pro (stable version), dropbox, logitech mouse software, coretemp, display fusion, google update, 7 sidebar widgets/gadgets and music manager.
