Dear Rats,
The last 6 months have been bad. Without going into details - I've lost most of the things I cared about in such a short period of time. Training was my source of outlet. Unfortunately I can no longer turn to that since my surgery. Although I've returned to training 4 * a week I can only lift between 5%-50% of what I could.
The year I put into a second transformation has been mostly undone. I constantly feel low in energy and losing the will to stick it out.
Despite all the challenges I'm a half glass full guy and happy go lucky but I'm not quite sure where to go from here. I fully understand that the real challenge is in stand back up but I can't.
What's a bro to do?
See here UE: https://www.strengthshop.co.uk/strength-shop-steel-log-205mm-diameter.html
We built ours based on those measurements IIRC, or at least from a similar website.
OK Bro's, need some help, i need to get measurements on a lifting Log and a yoke. Anyone good at diagrams for engineering be very helpful, anyone has either kit would appreciate the measurments. M8 of mine is engineer he is gonna make me up some kit.
Thanks for the input guys really really useful, love that PDF random, amazing. Morba any measurments you can get be amazing.
By way of reward here is me lifting wore weight overhead than you can
Next time you'll start the rep from your shoulders rather than chin right?
Cracking press fella, I'd be well happy with a 110kg strict press![]()
Did some mobility work today.
Jebus, my groin is throbbing!
Don't worry about it, it'll be water weight or something along those lines.
The real issue will be if the trend continues for a few weeks.
kd
Yep, anytime fitness on the triangle, Clifton. It's quite good because it's got 4 olympic bars and 3 cages. It's also 24 hour. You get told off for chalk and no shoes, but you can just be sneaky!I've always done the same with SL, skip the first month or so that the spreadsheet generates. Maybe do the last set of everything as a Wendler style + set aswell? Where do you train Nitefly, Bristol amirite?
