There are 2 screw threads that stick out of the tube and there are holes in the base of the mount on the sight, you place the screws through the holes then use 2 fastening bolty things that screw on to tighten it. The trouble is the mount base is curved in the same way as the tube, so when you tighten the screws it always fits into the same position.
