Easy - That made me shudder and cringe.... I guess my wife is right " Cheap is CHEAP "
I have 3 of them remotes and they work really well with XBMC.
I have 3 of them remotes and they work really well with XBMC.![]()
Anyone using a usb-cec ? I think it'll only work with the TV remote, don't think the sky remote will be able to control xbmc though
Something I wanna do that's for sure!
Guys,
Sorry if this has already been posted, but a quick question.
Is it possible to boot straight into XBMC? So it's like an OS instead of having windows then load it as an app?
Thanks,
Jake
Had it been for myself I would agree but I'm back peddling my idea of cheaping it as I'm buying it for the wife and you know what they're like .... moan moan moan![]()
Thought you had a harmony one?
Get a harmony one!
{ Get the picture yet ? }I would love one but SWMBO lives in the dark ages, she can barely do the simplest of tasks.
I'm still trying to teach her how to use browser tabs{ Get the picture yet ? }
Me too, for the 3 xbmcs hereI have 3 of them remotes and they work really well with XBMC.![]()
. They take a bit of getting to work with Ubuntu, but it is quite simple if you can follow instructions.I would not really bother too much about a remote control that your better half can use, unless you have better luck than me. We have had expensive LCD Universal type remotes to replace the several needed for our system and my wife can still barely turn on the TV. Labelling up with stickers the individual remotes did not help much either. She will often spend ages just trying to get the TV to the right HDMI input and the sound to optical, never mind take the HTPC out of sleep. I did script all of that for one of the expensive remotes but that only changed the problem to something else.
That's where the Logitech Harmony remote excels. The person using the remote generally does not need to know about TV channles, HDMI inputs, etc. They have a bunch of labels on the LCD screen like, "TV", "Videos", and they just press a button and everything is set up for them - including changing HDMI input/outputs, sound through a receiver or not, etc. It's streets ahead of all other universal remotes.
That sounds really good.
It reminds me of the Pronto / Phillips type that I had a long time ago. I would connect it to the PC and customise the LCD window and make my own icons etc for scripted controls. All this was an attempt by me to make it easier to just switch on all the devices for the person using them. It sort of worked ok, until my Son broke the glass on the LCD and that buggered that up.
Since then my wife just passes me the basket of remotes to switch the TV and amp etc on.
Get a harmony one!
