As you can see - some nasty wakelocks there. Got rid of the mediascanner one I had before via full sd wipe.
I got to be honest, I thought they were pretty good. 13 hours use and no partial wakelock over 5 minutes? Have a look at mine...
(Granted, I think something's gone wrong with the Network Location, probably a reboot would fix it.)
Are kernel wakelocks not the ones that keep the phone awake when you're using it? I've only ever used partial wakelocks, which are the ones that wake your phone up when it's sleeping.
no partial wakelocks over 5 mins - but then why is my phone awake for 3hrs when my screen on time is 1.5? I only used my phone when the screen was on and I turned off all sync services.
45 minutes!?!?!? That's barely enough time to... erm... nevermind.
I'm on Ripper v9 with Jkay and JB Dom. No problems with it at all. It's actually too good as I get itches to flash something new, but no reason to.
Ouchies. Glad it's all gone well though. How long do you have the restrictions for?
WOW!
Sorry to hear about that stoosh but I am glad to hear everything has gone well with the operation etc.Hopefully you will have a speedy recovery and get some more time on the internet for some......erm..... well I better not say it on a family friendly forum!
I use Latitude, so I know that's big for partial wakelocks. You do seem to have next to nothing waking it. I don't think you'll get much better than that, apart from maybe the launcher thing.
I don't think my brain could handle all the excitement with what the internet brings!![]()
After another full wipe and have nothing syncing my batterylife is back to excellent, got rid of lightflow, 3g watchdog and cpu widget.
Yeah, I could probably have told these would cause some drain, the first two definitely. What did the CPU widget do? Show clock speed?
