Caporegime
- 13 May 2003
- Warwickshire
Just downloaded angry birds star wars, and it shows you the flight path of the bird before you've launched it! Wtf, and how do I disable it?
Known issues:
* Places you still cannot Flow: email fields, passwords, anywhere where the app doesn’t behave itself with SwiftKey, fields offering their own corrections on Android versions <= 2.2
* Selecting and deleting a chunk of text in Samsung email client on SIII and Note 2 deletes text before the cursor as well as after
* Slight jitteriness when toggling between Hindi and Thai primary and secondary layouts
* Turkish i still does not capitalise correctly
* Long pressing SwiftKey mic in Google Now causes the keyboard to disappear
* Occasional surprising capitalisations of flowed words
* Flowing through space often fails after relatively unusual words
* If you experience high memory usage after installing, this may be fixed by rebooting your phone
Does anyone use imedia lite?! I'm using it on my nexus 7 to stream to my lg TV but once in a while when watching a film, it will just stop, forcing me to exit the app, and restart it and fast forward t to where I was.
Changes in this version:
* Predictions (and Flow) now on in most places (exceptions: email fields, passwords, anywhere where the app doesn’t behave itself with SwiftKey, fields offering their own corrections on Android versions <= 2.2)
* Easier corrections – just tap on the word and SwiftKey will offer you 3 possibilities
* New languages: Thai, Vietnamese, Bosnian, Albanian, Javan, Sundanese (plus those added in 3.1)
* Features from SwiftKey 3.1: Berry theme, split layout in landscape on phones, Armenian, Azerbaijani, Georgian, Hindi, Hinglish, Irish, Macedonian, Spanish (Latin America) and Tagalog
* New layouts for Hindi and Russian
* Ukrainian landscape layout fixed
* Backspacing on to the final word of a multi word prediction (Flow through space) will now give better alternatives
* Typing style now inferred rather than a setting
* Long press delete accelerates after the first word
Bugs fixed:
* Flowing off shift no longer triggers a change in shift state
* Flow no longer gets stuck when you flow off the bottom of a page
* Quick period working after single letter words
* Arrow key repeats
* Learning when sending messages or tabbing between fields with the enter key fixed
* Azeri capital i behaviour corrected
* Estonian will now predict words containing ö
* Fixed force close on Beta predictions
* Flow trace no longer left behind after flowing
* Mounting an SD card will turn predictions off only if SwiftKey language packs are stored on that SD card
* Keyclick sounds no longer doubled
* Haptic duration made consistent with flow on and off
Known issues:
The actual flowing aspect is better than swype in my opinion, but the fact you can't 'flow' into search boxes puts me off and sends me running back to swype![]()
Remember, it is BETA, these things will work in the final! SwiftKey only update stable when everything works![]()
I've still got it installed, I'm trying out every update, always hopeful
much appreciatedYou can now![]()
awesome news!
lol
Hmn I'm nto entirely sure that would work very wellAll we need now is flow into a password field and we're landedlol
