Bit bored! My monk in D3 was a lot of fun, playing the Shadow... Good DPS, but soooooo boring!
Liking this a lot! However, I'm pants haha. Often getting lost, the maps are pretty open and no waypoints is a bit of a nightmare!
Can't even understand the minimap or the normal map.
Started playing last night and squeezed a couple of hours in and I must say I'm impressed, but what are the main stand out differences between this and D3? I have asked in-game, but get torn a new one for mentioning D3![]()
You can make pretty much any build, including a multitude of crap ones.
What type of weapon are you using on your shadow?
Im rocking claws currently with flicker strike and frenzy gives me crazy attack speed and using a frenzy charge with flicker strike lets you jump around targets hitting them its rather awesome.
Would u mind explaining the charges stuff?![]()
Use ice spear, cast one - move until he does his pull spell (pudge hook) - cast, repeat. Minions do nothing.Just got to the boss of Act 1 level 11 (or is it 12) And he just faced rolled me! Trying to build as a minion witch but he wipes them out so quick and I just get destroyed, any tips?
I like both this and D3, but I sort of dislike the skill system in PoE, it just doesn't float my boat I guess. Maybe it'll grow on me. It seems to be designed to make you have to remake characters because you messed up on the over complicated passive tree.
Can I buy gems anywhere? Or is it re-roll time?They are skills which net you Power/Endurance/Frenzy charges. Each 1 gives your char a certain bonus (tells you on the Charge page in the character menu) and you can get a couple of other minor ones on the skill grid.
I've seen Power Siphon, a not so good wand attack that gives you a power charge if you kill the target which dissipates in 10 seconds unless you get another kill with it which is pretty crap as they come cos it runs out far too quickly and the requirement is awkward.
Frenzy Shot (I think it was) basically just fires a standard arrow that if it hits gains a Frenzy Charge which dissipates if you don't generate another charge within 15 seconds. Got Pierce on it so can hopefully hit multiple enemies with 1 shot.
And there's a War Cry sorta thing that generates an Endurance Charge based on the number of enemies nearby.
Summoners are supposed to be pretty weak early on and really powerful late game. Without Firestorm I'd never have killed Brutus. Your other option is to party with people and go in as a team.
