- 20 Oct 2008
I de-lidded my chip definitely worth it.
How many additional MHz and/or what reduction in noise?
no reduction in noise as it's water cooler with the 680.
no real boost in MHz just 20 degrees cooler.
have been running a 4.9 but I've settled it back down to 4.5 @ 1.21 vcore as the MHz gained isn't worth the increase in temps.
http://www.hwbot.org/image/900738.jpg I've got better screenies at home of temps and tests
If the chips staying cooler, wont it last longer?
i still cant believe intel did this,such a cop out
.Or, don't know if anyone tried with a dremel drum sander, simply just sanding through the top edges of the heat spreader should not take much, and simply remove the center whilst leaving the outer frame for the CPU Clamp
Sounds way to drastic to sand down the heat spreader and more likely to cause damage than cutting the rubber seal would.
.Reduced temperatures are a means to an end, not an end in themselves.
IMO 60 degrees Vs 80 degrees makes no odds unless it allows the chip to be pushed further (and you actually do it) and/or it allows for a quieter machine. That's not to say that delidding shouldn't be done, even if it's just out of interest.
I see what your saying but the less time a cpu spends at high temps the better no matter what other benefits you gain from it.
