I had written a load of drivel but I'll cut to the chase:
For those of you who have cut and successfully got your body fat to a level where your abs are clearly visible... How do you do it? What specifically worked for you in terms of diet/exercise? I am doing everything right but my body is clinging on to that last layer, it won't shift. No alcohol, plenty of HIIT, limited simple carbs, limited calorie intake... but still not getting the results!
Should be back hitting the weights hard again mid Feb when my broken metacarpal is fully healed. I've been doing loads of cardio so perhaps sticking to a low-carb diet and hitting the weights hard will work better for me?
