Turn off DCHP on the service provider device and set the linksys to a fixed IP and tell it the IP of the service provider device, they can't be the same.
Decto, this is the bit I am trying to do now.. as I have no access to the ISP modem is it ok to ask them to assign me a static IP and configure that on my Linksys? I have given them the MAC address of the Linksys to assign it to and they say its going to take 24-48hrs.. so I have time to cancel that if needed.
cheers
I think perhaps I we may be talking about slightly different things.
First around the DCHP, the important bit is that the server IP is different than any other device in the network so that DCHP can't give the server IP to a second device. Reservation etc shouldn't be needed as the server should be permanently accessible via it's own IP within the local LAN.
With regard to the service providers device, I assumed that this is in your premises but as you can't admin into it, it's used only as a link to the internet.
Yes, I only really need access via the LAN, so asking the ISP for a static (costs me $60), is a waste of time for me?Are to you trying to Remote Desktop within your own Lan? I assumed you were but portforward and your service provider would be used to give you an external IP address so you can remote desktop from the wild. (not recommended due to security)
OK, I will ask this. My work is a partner with the ISP so I can bypass the helpdesk and get some good info I thinkWithin the Lan, if you can't access the service provider device then you may be able to avoid conflict if you ensure that the linksys hands out IP addresses on a different subnet .. e.g. 192.168.0.xxx if the service provider is in the range 192.168.1.xxx
is something that could only show up intermittently and then fix itself? If so, sounds like my problemIf both the service provider unit and the linksys are handing out IP's and acting as a gateway on the same subnet your switch may be confusing the routing.
This is done, server is on 192.168.1.50 and its configured as such on the server and removed from the Linksys reservation. The linksys range is 192.168.1.51 - 192.168.1.149. All other Devices have an IP reserved in the Linksys.
it is in my premises, and no doubt i could find the log in if needed, or ask the ISP for the details I need.
really appreciate the input mate.
andy
I bought my microserver in Dec last year - I just heard I only had up until the end of last month to claim cash back - is that right?
