The decats are bolted to the manifolds, The decat pipes I got are from toyosports. They had to be modified as the lambda boss was fowling on the alternator and they dont meet up with the rest of the exhaust properly so a lot of cutting and welding was involved. You also need a friendly mot tester afterwards
You could get the full decat manifold for the mk2 v6 but im guessing this would also require a lot of modification.
I got the decat pipes for £80 and fitting was about £200 as theres a lot of work involved!
The brakes were pretty simple, The mitsubishi gto calipers come in 2 forms, ones that take 297mm discs and the other takes 320mm discs i think as standard. Doesnt matter which ones u get they just require different brackets as the mounting holes are different. The guy that does the brackets is on mondeostoc.com. You need at least 10mm spacers with the standard st220 wheels as the calipers dont clear the wheel. The focus st discs just go straight on no messing
