I heard about the lag before,but luckilyI didn't experience any yesterday. I think I got to level 8. Unfotunately, after I killed the crab boss in the underground tunnels and I TP'd, whilst in town the portal disappeared and when I used the waypoint to get back to the cave the whole thing had reset, so I lost the loot it dropped. Killed the crab again with some cool traps.
I'd like to support these guys, but it's tricky deciding what to buy. Maybe one of the pets. Too bad those glowy things can only be used once from the look of it. It would be better if you could buy something which made all of your helmets/gloves etc glow. Otherwise when you find a better item you will have to get rid of your glowy one.
Town Portals vanish when the area they're in 'resets' if nobody has been in it for 8-15 minutes.
I think the item glows are 'reclaimed'. At least that is the impression I got from the patch notes. It binds the item to you and prevents it been merched until you reclaim the effect, so you can use it as many times as you like but only on 1 item at a time.
Buy extra stash slots, you'll definitely want them later on.
I'm about to cave in and buy my second set of 6 premium stash tabs ><
Piety was... rather easy on my Marauder. The General hurt like hell thanks to his Molten Shell. Kole was so retardedly OP, he could 2 shot me so I just ignored him. Piety I just stood in front of her and battered her to death with my Geofri's Baptism and she didn't do a great deal.
A word of advice for Marauders. Get 'Resolute Technique' sooner rather than later. I finally got it at lvl35/36, halfway through Lunaris Temple level 3 and it makes so much difference. Was just bouncing around with Leapslam for most mobs and instead of it sometimes missing it was just smashing everything I landed on, absolutely hilarious
until then my spec isn't finished
