Crysis 3 performance
Want this game but im not sure my 580 will handle it very well..........any news on titan yet? That'll be when I upgrade my card.
To be honest, it's just built on CryEngine3, how different can it be to Crysis 2, it's the same engine.
I've been playin 2 maxed on on my spec with 40-55fps no problem.
Long flowing grass.
I don't see a 580 'struggling' to play, scaling down the options was still a great looking game when I tried out the beta for actual IQ difference.
As shown by the Crysis2 mods,the original Crysis2 had poor textures and lazy modelling of things like leaves for example. So,Crysis3 is probably what Crysis2 should have been.
One person,in their spare time has done better than Crytek with paid people.
True, though we need to remember that he didn't design the game / engine from the ground up. :)
That even makes Crysis2 worse when you come to think of it!!:p
It does seem it was consoles which were the lead platform for the game.
Even the story was disjointed from the ending of Crysis. I really hope Crysis3 resolves it fully.
Looks like a proper rig punisher, with the visuals to match. :cool: Hmm, how much for a second 7970 now?...............:p
When Crysis 2 released it was missing anything to do with DX11. It performed really well but as soon as the DX11 stuff was all installed it really took some power to get it shifting.
The most notable upgrade in DX11 was the depth of things like pointing in bricks and track marks left in the roads.
After Crysis was released it was ****ged off for running so poorly, even on the highest end hardware. To stop this happening again they cut Crysis 2 down quite badly so that it would perform well.
Crysis 3 by all accounts and from what I have been reading is the blue milk of games. All of the full fat goodness has been left in and it will have people rushing out to buy new hardware so that they can turn it all on.
Crysis : Warhead was also quite heavily cut down. The enemy numbers were reduced as was stuff like the length of the blades of grass ETC and it ran much smoother than the original.
Those with a keen eye though could definitely spot the reduction of detail :)
OK just booted up Crysis 3 with max settings and TXAA High, 15 fps at 1440p on 680 SLI. Dropped AA down to SMAA and got 30 fps. AA off and got 45 fps.
This is all on the first level.
It uses 99% of both my cards. I put shading, shadows and particles down from very high to high and now I get 60 fps. This game is a beast.
This game is not a beast, it runs on xbox 360 7 years old hardware.
It is easy to allow users to change the game config to make the game unplayable. There won't be great visual improvement though. You only get a real visual improvement with a new engine, new game, new technology. Not by cranking up settings. That on;y makes minor cosmetic difference.
Thought I should drop this in here:
Console commands and description, there's loads so it's in the spoiler:
Field of View
CVar: cl_fov
Recommended to be placed in system.cfg
The vertical field of view in degrees.
This controls several individual FOV controls that you can tweak manually if you prefer:
cl_FOV – The main field of view
r_DrawNearFOV – the field of view for nearby objects (held weapon, etc)
pl_movement.power_sprint_targetFOV – The field of view while power sprinting
Default Value: 60
HUD Bobbing
CVar: cl_bobhud
Controls the amount of bob hud which is applied.
Default is 1.0
HUD Canvas Adjustment
CVar: hud_canvas_width_adjustment
Multiplayer only. Multiplies the width of the HUD’s virtual canvas in cases where it may overlap monitor boundaries in multi-monitor setups. NOTE: before this multiplier is applied, the HUD clamps itself to a 16:9 res.
Default is 1.0
Hud Hide
CVar: hud_hide
If this cvar is true the HUD will be hidden from view completely.
Suitable for screenshots or very immersive play. NOTE: This feature is not fully supported, and this cvar value might need to be reset in game, e.g. on loading a save.
Default is off (hud visible)
Music Volume
CVar: s_MusicVolume
Controls the volume of Music, in the range from 0.0 to 1.0.
Default is 1.0, full volume.
SFX Volume
CVar: s_SFXVolume
Controls the volume of SFX, in the range from 0.0 to 1.0.
Dialog Volume
CVar: s_DialogVolume
Controls the volume of Dialog, in the range from 0.0 to 1.0.
Max FPS Limit
CVar: sys_MaxFps
Limits the frame rate to specified number.
A value of 0 means no limit.
Default is 0
Input
Toggle Crouch
CVar: cl_crouchToggle
Makes the crouch key work as a toggle.
Default is on
Toggle Zoom
CVar: cl_zoomToggle
Makes the zoom key work as a toggle.
Default is on
Mouse Smoothing
CVar: i_mouse_smooth
Set mouse smoothing value, also if 0 (disabled) there will be a simple average between the old and the actual input.
(1.0 = very very smooth, 30 = almost instant)
Default is 0.0
Mouse Acceleration
CVar: i_mouse_accel
Set mouse acceleration, 0.0 means no acceleration.
Default is 0.0
Mouse Acceleration Max
CVar: i_mouse_accel_max
Set mouse max mouse delta when using acceleration.
Default is 100.0
Mouse Sensitivity
CVar: cl_sensitivity
Sets mouse sensitivity.
Default is 30.0
Graphics Features
Particle Collisions
CVar: e_ParticlesObjectCollisions
Recommended to be placed in autoexec.cfg
Controls what objects particles will collide with.
Default Value: Static (Low/Medium), Dynamic (High/Very High)
None: No particle collisions at all.
Static: Particles tagged for collisions will interact with static objects.
Dynamic: As with Static, but dynamic objects also.
Particle Motion Blur
CVar: e_ParticlesMotionBlur
Enables or disables motion blur effect on fast moving particles.
Default Value: Off (Low/Medium/High), On (Very High)
Force Soft Particles
CVar: e_ParticlesForceSoftParticles
Forces all possible particles to use soft intersections with geometry – increases the cost but will all but eliminate hard edges on particles.
Tessellation
CVar: e_Tessellation
Enables or disables DX11 ALL tessellation.
NOTE: Currently not tweakable in the latest build of the game.
Will be tweakable soon.
Water Ocean Tessellation
CVar: r_WaterTessellationHW
Enables or disables DX11 tessellation for the ocean water surface.
Pixel Accurate Displacement Maps
CVar: r_SilhouettePOM
Enables or disables the Pixel Accurate Displacement Mapping (VERY GPU intensive).
Real-time Global Illumination
CVar: e_GI
Enables or disables real-time Global Illumination.
Default Value: Off (Low), On (Medium/High/Very High)
Real-time Volumetric Cloud Shadows
CVar: r_FogShadows
Enables or disables Real-time Volumetric Cloud Shadows.
Default Value: Off (Low/Medium), On (High/Very High)
Volumetric Water Shadows
CVar: r_FogShadowsWater
Enables or disables the Real-time Volumetric Shadows underneath water.
Screen-space Reflections
CVar: r_SSReflections
Enables or disables the Screen-Space reflections effect on glossy or reflective materials.
Depth of Field
CVar: r_DepthOfField
Enables or disables the depth of field blur effect.
Default Value: OnNOTE: Currently not tweakable in the latest build of the game.
Explosion Blur
CVar: g_radialBlur
Enables or disables the radial blur effect applied after an explosion.
Default Value: On
Color Grading
CVar: r_ColorGrading
Enables or disables the artist controlled color grading post-processing effect.
Default Value: On
Graphics Tweaking
Sharpening
CVar: r_Sharpening
Controls the level of the post-processing image sharpening filter.
Higher values give more sharpening, but too high values will create artifacts
A value of 0.0 is off
Default Value: 0.25
Chromatic Aberration
CVar: r_ChromaticAberration
Controls the level of the post-processing chromatic aberration.
Default Value: 1.5
Filmgrain
CVar: r_HDRGrainAmount
Controls the level of film grain applied to the final image to help alleviate artifacts from lack of colour precision in 32-bit colour displays.
Default Value: 0.0
Bloom amount
CVar: r_HDRBloomRatio
Controls the level of bloom used to simulate over-bright areas of the screen
Default Value: 0.15
Bloom threshold
CVar: r_HDRBrightLevel
Controls the brightness level threshold used to compute bloom
Default Value: 1.0
Ambient Occlusion Method
CVar: r_ssao
Chooses the ambient occlusion method
Default Value: SSAO (Low/Medium/High), SSDO (Very High)
None: No ambient occlusion is used.
SSAO: Screen-space Ambient Occlusion.
SSDO: Screen-space Directional Occlusion.
Texture Pool Size (MB)
CVar: r_TexturesStreamPoolSize
Sets the size of VRAM that is available in a pool for texture streaming.
Value is in Megabytes, and may be clamped based on the amount of video memory detected
Default Value: 192 (Low), 384 (Medium), 512 (High/Very High)
Shadow Timeslicing
CVar: e_GsmCache
Saves GPU performance by updating distant shadows less often.
Default Value: On (Low) Off (Medium/High/Very High)
Shadow Casting Light Scale
CVar: e_ShadowsResScale
Controls the resolution of shadow maps used for individual shadow casting lights.
Value is an arbitrary multiplier, so doubling this will double the resolution of each light
Default Value: 3.4 (Low/Medium/High), 40 (Very High)
Tessellated Shadow Cascades
CVar: e_ShadowsTessellateCascades
Determines how many shadow cascades to apply tessellation for.
A setting of 0 disables tessellation in all shadows.
Default Value: 1
Shadow Pool Size
CVar: e_ShadowsPoolSize
Sets the size of the shadow pool render target – increased size produces more resolution available for, and fewer artifacts in shadow casting lights (NOT including the sun). Value should be a power of 2 (128, 256, …)
If the pool is too small to fit the minimum size for the shadow casting lights, the GPU will thrash and performance will be severely impacted
Default Value: 2048 (Low/Medium/High), 4096 (Very High)
Sun Shadow Map Size
CVar: e_ShadowsMaxTexRes
Sets the size of each sun shadow cascade – increased size produces more resolution available for sun shadows.
Default Value: 512 (Low), 1024 (Medium/High/Very High)
Global Illumination Timeslicing
CVar: e_GICache
Sets the number of frames to cache GI results for before regenerating
A value of 0 disables all caching and regenerates GI every frame
Default Value: 7
Global Illumination Iterations
CVar: e_GIIterations
Sets the number of iterations to perform when calculating Global Illumination
A higher number will reduce bleeding and lengthen the light propagation distance
Default Value: 10
Tessellation Distance Limit
CVar: e_TessellationMaxDistance
Changes the distance in metres where tessellation will stop applying to objects
Default Value: 30
Tessellation Triangle Target Size
CVar: r_TessellationTriangleSize
The length of a triangle edge in pixels to aim for when tessellating.
Default Value: 8
Grass Instance Animation Distance
CVar: e_MergedMeshesInstanceDist
Distance fudge-factor where interactive grass instances will stop animating.
Default Value: 4.5 (Low/Medium/High) 8.0 (Very High)
Grass Instance Max Distance
CVar: e_MergedMeshesViewDistRatio
Multiplier controlling where chunks of interactive grass instances will disappear in the distance.
Default Value: 50
LOD distance ratio
CVar: e_LodRatio
Controls how close objects drop to lower Levels Of Detail. A higher number means a longer distance before this drop happens.
Default Value: 4 (Low), 6 (Medium) 20 (High), 40 (Very High)
View distance ratio (General)
CVar: e_ViewDistRatio
Controls how close objects will stop rendering in the distance.
Default Value: 25 (Low), 35 (Medium) 100 (High/Very High)
View distance ratio (Vegetation)
CVar: e_ViewDistRatioVegetation
Controls how close vegetation will stop rendering in the distance.
Default Value: 21 (Low), 31 (Medium) 100 (High/Very High)
View distance ratio (Detail)
CVar: e_ViewDistRatioDetail
Controls how close certain objects marked as ‘detail’ by artists will stop rendering in the distance.
Default Value: 19 (Low), 24 (Medium) 100 (High/Very High)
Miscellaneous
Skip Intro Movies
CVar: g_skipIntro
Skips the introduction movies that play before the main menu at game boot.
Default Value: Off
Fullscreen window mode
CVar: r_FullscreenWindow
When enabled, selecting ‘fullscreen’ in the menus will use a window that fills the screen, allowing easy alt-tab.
Windowed mode will behave as normal.
Default Value: Off
Disallow Fullscreen Pre-emption
CVar: r_FullscreenPreemption
When enabled, Pop-ups such as instant message windows and other focus-stealing windows will not minimise the game.
Default Value: On
Force Output Monitor
CVar: r_overrideDXGIOutput
Gives the number of display to use when creating the game window. 0 is the default/primary monitor and 1, 2, etc are displays after that. Allows you to create the window on a different monitor from your primary monitor (e.g. a TV or other external display)
Default Value: 0
Multi-GPU Support
CVar: r_MGPU
Determines Multi-GPU support in engine.
Default Value: Autodetect
Disabled: No multi-GPU support.
Forced: Multi-GPU support is force-enabled.
Autodetect: CryEngine auto-detects whether or not to enable Multi-GPU support.
Hardware Gamma Level
CVar: r_Gamma
Changes the hardware gamma level. Affects desktop as well.
Default Value: 1.0
Internal Occlusion Culling
CVar: e_CoverageBufferReproj
Controls the internal occlusion culling. You shouldn’t need to modify this cvar, but if you encounter any popping with rapid moving, experiment with disabling this.
Default Value: On
Game Network Port
CVar: g_blaze_gamePort
The network port games connections will be made on.
Enable Blaze VOIP
CVar: net_blaze_voip_enable
Toggles whether Blaze VOIP is enabled or not.
Default Value: On
Enable Blaze VOIP PTT
CVar: net_blaze_voip_enable_ptt
Toggles whether Blaze VOIP Push-to-talk is enabled or not.
Default Value: On
Enable Blaze VOIP
CVar: net_blaze_voip_playback_volume
Sets the Blaze VOIP playback volume, in the range 0.0 to 1.0.
Default Value: 1.0 Full volume
Has this released in the US yet?
I tried the vpn(US this time) again and it still wouldn't work.
You have absolutely no idea what you are talking about.
How about you go and look up the Samaritan tech demo.
