Not necessarily, he just needs to eat way more than 2200 on feed days.
Bro, don't confuse things
I posted an intermittent fasting protocol and asked 'is this OK?'. I was then told that I was a bad idea and only suited to manlet and those who weren't scared to lose their sweet gainz.
I then posted a response saying that, actually, this was a perfectly reasonable path to go along to lose some weight - no better or worse than any other although some emerging evidence suggests that IF might have other health benefits.
What am I rebutting?![]()
Either way i don't see the point in doing this when you could just eat at a consistent rate every day.
Sorry that our criticism didn't meet your expectations :'(
Help us to do better next time by taking a moment to fill you our feedback questionnaire - be sure to deposit it in the tray marked "DILLIGAF".
I was told that 600kcals EOD is bad - when really that was fine, it was the amount of kcals on the feed days that needed to be upped.
Skeptic
WHAT ARE YOUR GOALS?????!!!!!????!?!?!?!?! my first response and one of the first replies to your post i asked this and no answer.
If we dont know your current position we cannot provide even more detailed information in to why this isnt the best, safest, healthiest way of achieving what you want to achieve.
How heavy are you currently, whats your goal weight etc?
If you feel your grip is holding back your work then straps are there to help.
HOWEVER, I personally feel that by jumping onto straps you're also missing out on some good grip work. Though saying that I do very little grip specific work.
A few things that may help are:
Plate pinches
Fat gripz on dumbells/barbells when doing some of those exercises or alternatively do towel holds - i.e. hang a towel and grab the 2 halves and try and hold yourself up as long as possible - holding onto a towel is hard and creates a great forearm pump.
Static holds
However, I'm not a fan of grip specific training - things like captains of crush are a waste of time as they just train crushing strength. I mean you can do things like finger press ups, rubber ball pinches etc... but I wouldn't spend time in the gym specifically training grip.
I do deads before my pull ups, and then finish off with some DB rows with fat gripz - the make the dumbbell handle VERY thick - i.e. around 4" in diameter.
So my grip does get hammered.
This has taken years of training without straps. When deadlifting try DOH grip as much as possible. When putting plates away, or moving plates, try doing them with plate pinches instead. When doing chins, when you've finished your set - just try and hang there as long as possible - if you get forearm pumps and pain it means you're doing it right. Also, white knuckle grip - i.e. concentrate on holding on as tight as possible.
Grip is a slow thing to develop as it's mainly tendon work, and they take a long time to strengthen - as typically we don't give them enough recovery - but that's just the way it is! Nothing to try and avoid.
Sorry mate I didn't see this.
I've been out of the gym about a year, so looking to shift the bit of fat that I've put on since, and then to start back w/ intensity. I am 1.80m and ~13st. Want to get back to 12st.
I think we should just move on now. I concede that I should eat more on eating days - which will not be a chore![]()
Thanks for this. I'm going to look at some Fatgripz and some of the methods you suggest. Will report back after the use of my fingers and wrists come back![]()
Just had the most delightful fish in a batter sauce with chopped up potatoes for lunch. Taking healthy to the max![]()
Woooooooooooooooo 130KG Squat today new PB, form felt TIGHT as a drum. Chest up, sitting back not folding forward. Felt easy, only difference to what I normally do? Took a sugar free energy drink packed with caffeine felt absolutely amazing. Could have probably got 140Kg if I tried. Flew up. Feel awesome right now.
Anyway that's it for chasing numbers. New PB in squat and deadlift this week, enough of PBs time to get regimented, work on bar speed and reps and tight form. Even though my squat form felt fantastic.
Yeah... just be careful with that.
Great lift, regardless. Depth?
