show the bow ^^
Is it your regular attack dps that's down or your skill dps? And which skill/supports is it using if its the latter.
Cos damage wise, your old bow was doing 42-195 and your new bow is 48-178 so your average will be a bit lower ignoring damage nodes (and attack speed cos they're so similar).
I would've expected with elemental nodes you'd do more damage than before, depending on how many physical damage ones you took along the way.
And skills like Lightning Arrow take a portion of your physical damage and convert it to Lightning don't they? So if you deal more physical damage and you have 1 of those '30% Weapon Lightning Damage' nodes your old bow would have dealt not only more lightning from the straight up damage but more from the converted lightning damage too.
But don't quote me on that cos I'm at work so can't check things![]()
Until you start messing around with damage vs crit anyway...Bah, I'm almost out of scrolls of wisdom of all things! I'm farming for currency because I have become obsessed with linking the 5 sockets on a 2H mace I found (which is only a white plated maul, but hey, obsession) so I need about a billion orbs of fusing. Selling unidentified blues gives only two shards of transmutation, so it would take 160 blues just to get one orb of alteration. Identified blues normally give at least a couple of shards of alteration, so it's obviously much better to identify them when farming for currency.
But I'm down to ~40 scrolls of wisdom now. Is there an easier way of getting more than horribly tedious farming whites and hauling them to waypoints a few at a time (to avoid using up portal scrolls)?
to add the dps info of the skill shows me that i only lose 30dps, but i always felt these numbers are screwed by using i.e. lightning arrow and i don't think the ae dmg is calculated with it.
but i might just bump up the quality of the bow and see what happens.![]()
Perhaps not what you want to hear but I would suggest simply levelling. There is a decent chance you will find an appropriate weapon as you level and you might well find other items you can sell (whites with multiple linked slots, etc.). I think you might well get what you want faster that way, and its certainly more fun.......
So why are you searching for an elemental bow with that much physical damage? O_o
You're talking an 80% boost to physical damage, no wonder your old bow was stronger![]()
I am also running a elemental bow build (was doing it with a templar but now rolled a shadow). I have 2 bows, one adds more lightning but has less physical damage, the other is opposite, more physical but less lightning. Should I go for the one with more lightning rather than physical considering i am using lightning arrow and ice shot as my main skills??
Also, I am only around lvl 35 (have re-rolled like 4 times over lol) but if anyone wants to group up and or chat, my in game name is FrictionX, add me![]()
because i couldnt find any better. If you've taken all the elemental nodes which i guess you having judging by your current lvl then id take the ele bow otherwise take the physical one for now.
