Unigine Heaven 4 benchmark
13 Nov 2007
GPU: 2 x 7950 @ 1175/1575 (16x & 8x PCIex 2.0)
CPU: i7 920 @ 4.2
Man of Honour
OP
21 May 2012
Dalek flagship
Is it common for scores to jump up and down by a few hundred even if core settings aren't changed?
Not normally, if the settings are unchanged you may get a difference of 20 or 30 points.
Just a guess but if you are getting a very big variation in scores for the same settings, have a look at your temps/cooling.
Permabanned
25 Jan 2013
I'm using Precision to monitor temps and power useage during benchmarks and they seem to be pretty consistent every time... weird. I'll set things to default later and have a dabble about to try and determine the problem.
Caporegime
24 Sep 2008
Essex innit!
+143 Core + 333 Memory
CPU 3930K @ 4.625
Done fairly this time :D
Edit:
I set those clocks but when I came out, I noticed the Core had boosted to 1143Mhz but memory was the same. Just giving the info of what is what :)
19 Oct 2008
CPU 3930K @ 4.625
Edit:
So two titans overclocked are nearly double the performance of a stock 690 in this test ( 120.4 vs 64.6)? That's not bad at all.
6 May 2009
Cant you just get 2 x 690s? wouldn't it be cheaper and faster?
edit - looks like it is - 1. Score 3520, GPU 690 x 2, @1066/1800, CPU 3960X @4.9, Kaapstad
edit 2 - scratch that, the cheapest 690 is £800 :eek:
