Cobbles are no longer needed, just the results screen anywhere in Heaven 4 - yours is fine.
Some of the info Heaven 4 shows can be a bit odd.
Could you confirm your CPU speed please.
Updated
Is it common for scores to jump up and down by a few hundred even if core settings aren't changed?
Not normally, if the settings are unchanged you may get a difference of 20 or 30 points.
Just a guess but if you are getting a very big variation in scores for the same settings, have a look at your temps/cooling.
Update... first OC run
Win 8
Gigabyte GTX TITAN @ 1001/1040 1502/1510 837/876
Intel i7-3970X @ 4.4
CPU 3930K @ 4.625
GPU's both at +143 Core and +308 Mem
If I have something not correct in settings, please let me know (my score seems way too high).
You need 8x AA![]()
I guessed I had missed summit. Will rerun again soon.
Anything to beat those guys in the red shirts.![]()
+143 Core + 333 Memory
CPU 3930K @ 4.625
Done fairly this time
Edit:
I set those clocks but when I came out, I noticed the Core had boosted to 1143Mhz but memory was the same. Just giving the info of what is what![]()
CPU 3930K @ 4.625
Edit:
So two titans overclocked are nearly double the performance of a stock 690 in this test ( 120.4 vs 64.6)? That's not bad at all.
That's the way it seems to be working, if you overclock a Titan it gets very close to a GTX 690 @stock.
For a single card that's very impressive!
